I didn't realize that you already had splitters in the line (good catch, teleview). Believe it or not, but a splitter does not transfer power completely from input to outputs. An unavoidable property of radio/TV connections is reflections. Some power is always reflected back to the source.
You have very strong signals, which amplify the effects of reflections and mismatches and loose connections. Teleview's recommendation of simplifying your setup is sound. Directly connect to one tv and see what you get. If you still have problems, then twiddling with the antenna's aim first, then adjust the antenna's height.
Once you're set with one tv, go with the splitter teleview recommended. It will be far better to run extra cable then have a bunch of connections.
Good luck!
