Old 9-Jun-2010, 4:46 PM   #5
Originally Posted by Jnktwnman View Post
My installer has said that I should try an amplifier at the set -
That's bad advice from the installer. It makes me wonder if the antenna is even aimed properly.
The antenna is fine for your location. No preamp is necessary.
If the UHF stations that you're having trouble with are WNJS, WMCN, and WNJT, they are not the same direction as the Philly stations. You can solve that problem with a second antenna and an A/B switch or a rotor on your current antenna.
Of course the advice to check your connections is also valid.
