Old 3-Jun-2010, 11:06 PM   #1
ta240
antenna suggestion for 1 VHF channel
Tried a Clearstream4 in the attic with a very small amplifier (from a flat antenna I was removing) and got decent reception on CBS, Fox and NBC (at the 173degree) but couldn't pull in the VHF KXTV channel for more than a couple blips on the screen. Would prefer to put the antenna in the attic but if I could get away with one the size of the CS4 or smaller I wouldn't mind putting it outside.
Add an VHF only antenna? Inside? Outside?
Better UHF/VHF? inside? outside?
Bigger Amp?
Recommended antennas?
http://www.tvfool.com/?option=com_wr...9fbe613badcf8b
ta240 is offline   Reply With Quote
