After looking at your situation a little longer, you might be able to get by with separate UHF and VHF antennas, with the VHF antenna aimed at 141 degrees and the UHF antenna aimed at 11 or closer to true north. The key is the FOX station at 159 degrees. It's a very strong UHF, so you could rely on a sidelobe of the antenna aimed at north, more or less. For VHF, use the AntennaCraft Y5-7-13. For UHF, I'm still pondering (anybody else have a recommendation?). Combine the two with a USVJ and you will be set.
