Old 24-May-2010, 10:16 PM   #5
Dave Loudin
Your issue is likely too much signal. Your tuner is overwhelmed and turns down its sensitivity. DO NOT use any kind of amplified antenna, it will just make the situation worse.
There are two ways I can think of to go. First is to get a simple loop/rabbit ears combination - cheap! You don't need sensitivity, you just need some sort of directivity (favoring one direction vice another) to isolate the best signal direction. The other way to go is with the Terk HDTV (the unamplified version). It has better directional properties (which you need) with more gain (which you don't).
Good luck!
