Old 24-May-2010, 2:55 AM   #6
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
The HD-7696P is a wise choice, but I would skew the aim slightly so the antenna sees KCPQ clearly: try about 150 degrees instead of 130 for your aiming. If you plan to run two or more TV sets, I suggest using a high-input preamplifier like a Winegard HDP-269, which will overcome the line and splittine losses associated with tunning multiple TV sets.
