Old 24-May-2010, 1:39 AM   #16
salvasol
I found this information about my antenna VU-75XR VHF/UHF/FM Antenna
(150-2151) Specifications Faxback Doc. # 38046
Average Gain (Low Band [VHF] Channel): ............................ 2.8 dB
(High Band [VHF] Channel): ........................... 5.8 dB
(UHF Band Channel): .................................... 5.6 dB
(FM Band [MHz]): ....................................... -0.8 dB
Median Av. F/B Ratio (VHF Low Band): ................................. 8.0
(VHF High Band): ........................................ 9.0
(UHF): ..................................................... 15.0
(FM): ....................................................... 6.0
Average Half-Power Beam Width (Chan. 2 - 6): .................. 69 degrees
(Chan. 7 - 13): .............................. 49 degrees
(UHF*): ........................................ 54 degrees
(FM): ........................................... 72 degrees
* At Chan. 30 (566 MHz)
Can somebody tell me what can I do to improve reception (if it can be done with this antenna) or What antenna can I get to upgrade... I prefer to stay within 60" - 90" max lenght
I been considering winegard 7694p or maybe 7695p, another option is the Antennacraft HBU33. I want to avoid to get anything bigger......
From the tvfool list....I'm trying to receive all the way to KCET(28.1) or at least KMEX (34.1) then I'll be happy.
salvasol is offline   Reply With Quote
