Old 22-May-2010, 7:10 PM   #12
Tower Guy
Originally Posted by lodger View Post
I'm having trouble capturing the ABC signal ever since I hooked up my digital tuner in a new neighborhood.
The signal from WMMR-FM on 93.3 is 20 db stronger than WPVI. You could try an attenuator or an FM trap.
With patience you may be able to find a spot for your antenna that tends to get WPVI better than WMMR. The process will be more difficult because WPVI is no longer stored in your channel map. You must adjust the antenna, rescan; adjust the antenna, rescan; over and over and over again. (You would have been better off if you had not rescanned.)
