Old 21-May-2010, 7:16 PM   #4
Lightbulb Tv reception
Due to the WIDE SPREAD of television transmitters the winegard GS 2200 will not work at your location. The GS2200 is a bidirectional , 2 directional antenna , forward and back , not side to side. . . IF you will be connecting one Tv , then I suggest the http://www.antennacraft.net/HDView360.html . . . DO NOT put this antenna on the same mast as the satellite dish antenna. Mount it on a separate mast , I suggest a tripod antenna mount on the roof. It is best with broadcast television antennas to get them UP in the Air , clear of obstructions that can block or degrade a broadcast television signal.
Last edited by teleview; 21-May-2010 at 7:19 PM. Reason: Spelling corrections and update/clarify information.
