Cutting through all the clutter...
Your existing antenna needs to be both adjusted and positioned for the best shot at WPVI. WPVI transmits on a frequency just below the FM radio band and requires a long antenna to be naturally effective.
Extend the elements fully. Lay them down so they are both horizontal. If the tip-to-tip length exceeds 65", shorten them to make them that length. If they are not 65", leave them as long as you can.
Place the antenna broadside in front of a window that faces generally north to north-west.
That's as good as it is going to get with your existing antenna.
