Old 21-May-2010, 5:23 PM   #2
Dave Loudin
Looks like you have a clear shot at all the locals with plenty of signal, which is good news. Before we can give you a particular recommendation, you need to rerun you TVFool prediction at your exact location. Use the "Start MAPS" option, specify as much of your address as you want, then drag the map pointer to be right over your location. Adjust the antenna height to the anticipated height you would put your antenna, then plot the results.
Using a settop indoor antenna could be iffy, since you will be in a metal box. Best bet will be outside, but which antenna depends on your follow-up posting.
