Old 27-Dec-2011, 6:15 PM   #5
I would never call an omni-directional antenna "dependable". As the expression goes, "An omni-directional antenna receives equally poorly from all directions" because it has zero resistance to that bane of digital reception, multi-path.
That said, an omni is a viable antenna to attempt as long as it is approached with realistic expectations. If it works in your particular situation - "Mazel tov!". If it doesn't, then alternatives will need to explored.
I agree. I regret the one occasion that I did recommend one.
