Tv reception
When the UHF channels 70 thru 83 went away it took the manufactures awhile to rescale to 14 thru 69. Manufactures are waiting to see what will happen with the VHF high and low bands. You are making a mountain out of a french fry. You can do the cut to channel and stack em. . . . . . http://www.go2mhz.com/specimages/Wade/Taco%20uhf%20CATV%20and%20MATV%20Antennas.pdf http://www.go2mhz.com . . http://www.wade-antenna.com . . . . Or you could strap on the PB-82-BB . http://www.go2mhz.com/specimages/Wade/D1338-BB.pdf . Or you could even do this . http://www.wade-antenna.com/Wade/CircularHelical.htm . . . . http://forum.tvfool.com/showthread.php?t=410
Reason: Spelling corrections and update/clarify information.
