Old 19-May-2010, 10:11 PM   #2
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
You have some reception issues do be dealt with to insure that you get all your networks: NBC will only be available to you from a translator on channel 40 that broadcasts in analog only: FOX and ABC will be easy. PBS will be difficult, as it is on a low-power translator on channel 4, and CBS is likely to be a no-show, as it is severely blocked by hills. I can say that you are likely to only see 3 TV stations clearly, and that only 2 of them will be digital: my suggestion would be to get a small all-channel antenna like a Winegard HD-7015 and aim it at 235 degrees, as measured by your compass. The other stations listed are too blocked by hills to expect to get any reception.
