Tv Reception with Tv antennas
DO NOT use a amplified antenna of any type or kind for reception of local tv stations, the amplifier will overload from the strong signals and be the cause of bad or no reception. DO NOT use a lava , lavas are cheap flimsy junk. I recommend a Winegard MS1000 antenna , inside or outside. If you have a balcony to the south , put the MS1000 on the south balcony for reception of the Canada and USA digital stations.
