Old 25-Dec-2011, 2:28 AM   #9
No static at all
No static at all's Avatar
Originally Posted by ghz24 View Post
Power lines are that noisy? Is it no quieter 40 ft in the air than inside the house?
Yes, but the power lines themselves are not the only culprit. The connections between the lines & transformers can emit high levels of noise (static), especially if not properly tightened. It is worse when the humidity is low & barely evident when humid. I've even seen analog UHF affected at my first residence in the winter time. This is not an issue with underground power distribution from my experience.
Once the power is stepped down by the transformer & enters the house, it shouldn't be an issue.
