Old 24-Dec-2011, 8:45 AM   #6
ghz24
the earth turns and later the Milky Way is in the main beam of your antenna.
There were patterns that I thought were more heat/cool air turbulence scatter type.Looking back they seem pretty sharp daily time wise.
That would explain a lot.
buried power lines and no part 15 devices in your house
Power lines are that noisy? Is it no quieter 40 ft in the air than inside the house?
Since I plan on mounting a tuner on the tower would powering it with 12 v DC help noise interference wise?
I'm a little confused on how the interference gets into the tuner (other than through the antenna ) seems it can leak in every where.
The plot for my locale reports a 1 dB better sweet spot at 23 ft to get a reported NM of 16 again takes a height of over 100 ft.
ghz24 is offline   Reply With Quote
