Old 23-Dec-2011, 8:40 PM   #2
Dave Loudin
James,
Click on any of the stations in the table of your report and you will see the path profile used by TVFool in generating the signal predictions (transmitter on the left, you on the right.) You'll see that the mountains about 8 miles or so away seriously block your ability to see the Los Angeles stations. In fact, every signal available to you has to scatter over a ridgetop.
It's possible to put a couple of hundred dollars into a deep-fringe antenna system (stacking two high-gain antennas) with a low-noise preamplifier and see a few channels. I'm not confident that you will get the full complement of network affiliates reliably, however.
