Old 23-Dec-2011, 3:17 PM   #11
Tower Guy
Originally Posted by jonnybass View Post
Any suggestions on boosting that deflected 29.1 signal?
GUM, I love your analogy: "It's like you are trying to take a picture of a faint star that is just a few degrees away from the noonday sun."
The channel 14 signal may be weak or it may have interference. To determine which it is, you'd need a high overload resistant amplifier such as the Winegard HDP-269 and/or a channel 14 bandpass filter. The CF-7 from Tinlee is one option. http://www.tinlee.com/bandpass_filters.php#CF7
Tinlee is in Toronto.
Here's another option.
http://www.solidsignal.com/pview.asp...Hz-%28BPF-U%29
The filter must be installed between the antenna and any preamplifier. You'd have to remove it to use the antenna for other stations.
