Tv Reception with Tv antennas
My original recommendation of a HD7698P antenna and a YA6260 antenna is to make it easy to receive the stations in those directions , two antennas , two preamplifiers , and a remote control AB antenna switch makes it easy , no waiting for the antenna to rotate around on the rotor.
If you choose to use a antenna rotor. A HD7084P all channel antenna can be used with the rotor.
I know you say you are not interested in channel 4 , however I predict you will be.
The HD7084P antenna can also be aimed at the Madison tv stations as a test of reception. With all the choices presented with the others and Electron.
What would I do , I would install a HD7698P antenna and AP8275 preamp and a YA6260 antenna and AP3700 preamp. I would rotate the HD7698P antenna and preamp , by hand , around to get a idea of the Madison reception. If , some or all of the Madison stations are received with the HD7698P antenna and preamp , then the rotor could be used to receive the Cedar Rapids and Madison.
