Old 16-May-2010, 10:28 AM   #2
Lightbulb Tv reception
Looks like you know something about antennas and amplifiers now. .LPDA Log Periodic Dipole Array. The Log Periodic is the best for digital tv reception , they have a nice flat even responds across the tv channels. .The 'situation' tv station here is channel 10 PBS. I suggest 2 antennas and forget about channel 5 W05BV. 2 Winegard 7694P tv antennas , one pointed at channel 10 , 267 degree magnetic compass and one pointed between 35 and 16 , 345 degree magnetic compass. Both of these antennas are UHF and VHF high band antennas 7thru13. Connect the antennas with a Winegard CC7870 antenna joiner with equal lengths of RG6 coax cable, no antenna amplifier on the antennas . . If you will like to keep channel 5 then use 2 Winegard HD7082P antennas , the HD7082P has the long metal elements for channel 5 and connect the antenna amplifier to the antenna that is pointed at channel 5. One port on the Winegard CC7870 passes power , thats the one to connect with the amplifier. . http://winegardtvantennas.com . . The antennas need to be separated by 13 feet or more and mounted on separate antenna mounts , the southern most antenna is channel 10 and the northern most antenna is pointed between channels 35 and 16.
Last edited by teleview; 19-May-2010 at 4:15 AM. Reason: Spelling corrections and update/clarify information.
