Old 15-May-2010, 8:45 PM   #15
salvasol
Originally Posted by Tigerbangs View Post
I don't understand the issue; if you already have an antenna on the roof, why is it an issue to replace it with a larger antenna: it is a simple replacement? .....
Thank you for the reply.
The issue with another antenna is the size...like I said is an apartment complex, and I got away with this small antenna (first I installed the Terk HDTVo (much smaller) then I replace it with the RS, I'm the only one who has OTA, everybody has satellite or cable, but I want to avoid that expense).
I already installed the rotator, channel 24 signal is strong if I point the antenna to the right place, but it works if is pointing to Mt Wilson too.
I will check the coax (I was assuming is RG59 because is white, but I noticed that RG6 can be that color too...not just black )
Decisions, decisions, decisions....
Edit: I need a VHF/UHF antenna, Do you think a 7-69 is enough or do I need one 2-69???
salvasol is offline   Reply With Quote
