Tv Reception with Tv antennas
Thats some tricky wording. My eyes are crossed. As stated in my detailed post of the stations to be received by the HD7698P antenna in the direction of the Cedar Rapids Area Stations , ( I count 3 UHF Stations and 2 VHF high band stations) ( so nothing has gone to waste). , the HD7698P antenna receives the VHF high channels of 7 thru 13 and the UHF channels of 14 thru 69. NBC is a VHF high channel. . Swing the HD7698P antenna around to Madison does not make HD7698P antenna any less of a antenna , it is being used as a test. . If , as in , if the Madison UHF stations are received it will likely require a dedicated 91XG or Winegard HD9095 uhf antenna. or even two 91XG's with a preamp or two HD9095's with a preamp.
