Old 21-Dec-2011, 3:54 AM   #18
mdawdy
mdawdy's Avatar
Originally Posted by Electron View Post
Install a Winegard HD7000R antenna ... You can try the HD7000R antenna in the attic , however the HD7000R will need to be mounted above the roof. Here are some antenna mounts ...
Thanks for this info. I have not given up on an attic installation quite yet, but i suspect that in the end i will go outside.
Mick
mdawdy is offline   Reply With Quote
