Thread: hd stacker
Old 20-Dec-2011, 3:42 PM   #14
Tower Guy
Originally Posted by DaveBB View Post
I live in a very rural area in SW Wisconsin and the signals are coming from different locations.
How has your luck been with WHBF on channel 4? Do you know if the second KWWL channel 7 is actually on the air?
I would guess that channel 4 is not reliable and if KWWL-1 is on the air it won't work either. The FCC web site calls KWWL-1 a construction permit, not an operational station.
So, in order to get CBS you'll need KGAN on channel 51. Only the highest gain UHF antenna will work. A 91XG is one such option. Next you need a VHF high band antenna. This could be a Y10-7-13. The VHF antenna can be below the rotator and fixed aimed at 262°. Couple the two antennas before your preamp using a UVSJ.
