Old 19-Dec-2011, 11:18 PM   #16
mdawdy
mdawdy's Avatar
Be advised that the CC-7870 is simply a splitter made with ferrite cores. A good glass-strip splitter will do far better as a combiner.
I Googled glass-strip splitter but did not come up with much. I am not familiar with that terminology or with the term diplixer. Is this an example? ...
http://www.antennasdirect.com/store/splitters.html
This is quite an inexpensive part compared to the item i purchased. Does the description balanced low loss splitters / diplixers feature tin-plated zinc weatherproof housings, a DC pass port, and glass PCB micro strip design imply that it is a glass-strip splitter like you are referring to, and a combiner as well as a splitter?
If not perhaps you could get me an example?
Thanx.
Mick
mdawdy is offline   Reply With Quote
