Old 19-Dec-2011, 11:15 PM   #11
Originally Posted by Huntingfool View Post
I have a Radio Shack U4000 (4 bay) Antennacraft antenna. I am also using a Phillips pre-amp http://www.amazon.com/Philips-SWS208.../dp/B003QP42KU. I have a Magnavox convertor box model TB100MW9.
My report is as follows: http://www.tvfool.com/?option=com_wr...40334d066a5201
I get KATV (7.1) all the time (except during major storms). I get KARK (4.1) about 25 % of the time. The other channels show up on the listings, but I don't have enough signal to pull them in.
What antenna/pre-amp setup should I purchase to get all the channels since what I have isn't working?
I'm only interested in UHF. That's why I have this antenna but it only picks up one station consistently
Thinking of going with the xg91 from antennadirect.
I'm a bit unsure of your goals. "What antenna/pre-amp setup should I purchase to get all the channels...?" is contradicted by "I'm only interested in UHF". Total guess on my part... Do you think UHF=HD or digital and VHF=SD or analog? KTHV-CBS, real VHF channel 12 broadcasts two sub-channels, one is the primary CBS affiliate programing in HD 1080i 5.1 and the other is news in SD 480i - digital, ATSC, not analog NTSC.
The XG91 is an excellent high gain UHF only antenna. However, don't expect to reliably receive KTHV, K04RA, KEMV, KAFT or KETS with it.
The published technical specifications for the Philips SWS2083W/17 preamp do not include the noise figure or maximum signal capability. The preamp may be adequate... but the manufacturer doesn't provide the information needed to make an informed decision. If I were starting from scratch I would look at the Antennas Direct CPA-18.
As I mentioned earlier, I would also include VHF capability if I were building an antenna system next door to you.
