Good for use in Western Europe
I have no first hand experience with these antennas.
The manufactures published performance data clearly indicates these are designed to perform well at frequencies above the US television channel assignments. (The US high-VHF band is from 174 MHz to 216 MHz. The US UHF band is from 470 MHz to 698 MHz) The peak gain is in the cell-phone/PCS band... too bad your cell phone isn't equipped with a 75 ohm F connection.
One of our on going problems here in the US is that many existing antenna designs are optimized for the pre-2009 UHF spectrum that included channels 52 to 69 (698 MHz to 806 MHz). This results in antennas that have less gain than would be possible if they were optimized to cover a narrower range of frequencies. (As I say this, I get frustrated at the FCC's decision to sell spectrum out from under the tax paying public. I long for the days when UHF antenna design needed to account for more bandwidth.)
http://en.wikipedia.org/wiki/Televis...el_frequencies
