Old 15-May-2010, 1:26 PM   #1
msu2
What antenna setup would you suggest?
Hello, and thank you for considering my situation.
My TV Signal Analysis Results are here
The antenna will be mounted on the roof of a home that is located under a canopy of large oak trees. The previous antenna (I don't know the make/model but it was an LPDA type antenna) was damaged by a falling tree limb.
The signal is currently split 4 ways in the attic using an Electroline EDA-UG 2402.
There is also a Channel Master CM 7777 Titan2 attached to the system.
Thanks for your time and input,
Phil
msu2 is offline   Reply With Quote
