Old 18-Dec-2011, 10:31 PM   #1
timotb
New set up in Canton Ohio
http://www.tvfool.com/?option=com_wr...4033328f8cf7ae
I bought a cheap 125 mile antenna on ebay, The WA830TG. Reception is good when the rotor doesn't get stuck. Otherwise I have to look outside to see the current position and move it guessing the correct azimuth for the desired channels.
It appears I have two strong areas of channels, 310 degrees and 070 degrees. Forget channel 47, its all Religion. Im interested in WJW and WUAB, both should be strong but I receive neither.
I will probably send this antenna back since I have 60 days to try being the rotor gets stuck often. Finding a quality antenna is my goal.
timotb is offline   Reply With Quote
