Old 18-Dec-2011, 6:59 PM   #4
Tv Reception with Tv antennas
This recommendation is based on the tvfool current and Pending Applications Included , with exact address and antenna height of 25 feet. The antennas will be above the roof. Install a Winegard HD5030 antenna aimed at 306 degree magnetic compass for the reception of K04RA-D 4 America One Tv http://americaone.com and KAFT 9 PBS. . . Also install a Winegard HD7698P antenna aimed at 134 degree magnetic compass. For the reception of , KTHV-DT 12 CBS , KARK-DT 32 NBC , KARZ-DT 44 MyNetwork , KLRT-DT 30 FOX , KATV 22 ABC , KKYK-CD 20 This Tv. . . Separate coax from HD5030 and the HD7698P will go to the location of the tv. Do Not combine the two antenna coaxes on to one coax. The two separate coaxes will be connected to a , http://www.mcmelectronics.com # 32-4425 or http://www.radioshack.com #15-1968 , remote control A/B antenna switch and the output of the A/B switch is connected to the tv. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. Here are places to by antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
