Old 18-Dec-2011, 4:26 AM   #4
86waterpumper
Thanks for your help. With my 8 dollar rca rabbit ears, I can pick up the local wbbj channels very well. Like you mentioned, after jan. 1st we are getting cbs added to the local stations so that is a plus.
At times I struggle with the wjkt and wljt stations but they also do come in sometimes with 4 or 5 bars signal strength. I know I would really struggle to get any stations out of memphis without alot of work, so what I really want is just to pull in the ones I can already get with more authority. Since I can already get these depending on the weather etc I had hoped to not have to roof mount and get away with a much better antenna mounted in the attic. Could I mount the HD7084P in the attic and try it that way first? Surely I could pull in alot more doing it this way than with the antenna I have? The current one I am using is rca ANT111R, data code 2114 ph. If there is a more suitable antenna for attic mounting what would it be?
86waterpumper is offline   Reply With Quote
