Old 18-Dec-2011, 3:56 AM   #2
Electron
Tv Reception with Tv antennas
This recommendation is based on the tvfool radar report of the current and Pending Applications Included for digital tv channels. The digital tv stations in the pink/red zone are Very Weak of signal strength. Reliable and dependable reception means that a Winegard HD7084P antenna will be installed above the roof and aimed at about 249 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/345424560.html , http://www.ronard.com/ychim.html. . . WBBJ , WLJT , WJKT , are close and are Very strong tv transmissions so these 3 stations will likely be received through the back and side of the HD7084P antenna. This way only one antenna is used and no antenna rotor is needed. Install new RG-6 coax on the outside. Here are places to by antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com , http://www.3starinc.com
