Old 16-Dec-2011, 11:34 PM   #13
slowhike
Another issue that I haven't mentioned is large oak trees on both sides of my house.
My property is not far from the highest in my community, so that should help, but the trees are nice & thick with leaves in the summer & quite a bit higher than my roof peak.
Most folks are looking for simple and reliable.
Any of the reputable antenna brands 4-bay UHF panel antenna facing east would give you a fairly comprehensive line-up.
U4000, DB-4, DB-4e, CS4, CM-4221 or HD4400.
http://www.antennacraft.net/Antennas/AntennasUHF.html
http://www.antennasdirect.com/store/...-Antennas.html
http://www.channelmaster.com/Channel...ntenna_s/3.htm
http://www.winegarddirect.com/cview....nly%20Antennas
However, at the risk of being more complex, if you want to see the signals from other directions, I was thinking of a Winegard HD7698P plus preamp (CPA-19 or HDP-269) and a rotator (NTE U-106 + TB-105). I was thinking of a somewhat unconventional method of connecting the two antenna systems: http://forum.tvfool.com/showthread.php?t=2882
The result is that you would end up with one antenna feed that would serve general viewing needs. You would have the option to run the axillary antenna to one, some or all sets... depending on your preference. (For the sports fan with a "man-cave" TV, wanting to see signals from out of town, this idea may make good sense.)
This idea can easily fit on a tripod and 10' mast section. The larger rotating antenna would be at the top.
I have been looking at the links from GroundUrMast. It seams there is quite a range of prices for the fixed antennas, from 21.89 to 89.99. I realize prices will vary as I shop around. But although cash is a little tight right now, I don't want to scrimp on this project.
If I try a fixed antenna & later decide I want to try a multidirection w/ preamp & rotor, I'm thinking that it was said earlier that I could still use the fixed in conjunction with a rotating, multidirection.
But maybe I'll be satisfied with a good fixed antenna (or two).
I have thought about the more complex alternative GroundUrMast talked about, but when I read the post he linked http://forum.tvfool.com/showthread.php?t=2882
I start thinking I might get into more hassle than I know how to deal with
If I were going to go with the more complex system, I would like to try to buy most if not all of the components from the same place, so I could take advantage of a 6 months/no interest deal & pay it off in steps. I can get most of the listed items from Winegard except the rotor. What are your opinions of the rotors offered by Winegard?
http://www.winegarddirect.com/sview.asp?q=rotor
Originally Posted by scott784 View Post
GroundUrMast, it looks like you've given Tim a lot of excellent information and links to check out.
As for general topic (on this thread) about his signals coming from different directions around the compass, that is true. But the majority of what Tim would receive (in the green) are coming from the towers to his E/SE near Randleman, NC. The exception to that (in the green) is WXII and WUNL on Sauratown Mtn (to his north).
The majority of his stations in the yellow area, are the neighboring market locals (Charlotte). Those towers are to his S/SW from NE Charlotte and Dallas, NC (near Gastonia, NC).
I just mention these specific locations for the benefit of this poster (Tim) as I live in his same general area. From his tvfool report, it looks like he has very good potential for OTA reception.
Thanks for the local info on directions Scott. Very helpful.
I'm thinking from this that maybe two (or even three?) fixed direction antennas might do the trick. Only concern is that all three directions you mentioned will be pointing through the large oaks & I'm not sure how much that is going to interfere.
Have you told elsewhere here about the stations you pick up Scott?
slowhike is offline   Reply With Quote
