TV Fool Report from http://forum.tvfool.com/showthread.php?t=6776 --- http://www.tvfool.com/?option=com_wr...403391070aeb02
Based on this I would expect an RCA ANT-751 pointing at about 320° to receive the stations NW and SE of you. That is, if you mount outdoors and high enough that both the front and back of the antenna are not blocked by the roof or other construction.
The Channel Master CM-7000 is worth looking at. http://www.channelmasterstore.com/Di..._p/cm-7000.htm
Amazon has several STB/DTV converters, though the choices change nearly day to day it seems.
Reason: OP provided TVFR link
