Old 16-Dec-2011, 5:41 PM   #6
mdawdy
mdawdy's Avatar
It would help us understand your situation better if you were to post a link to your TV Fool Report ...
My apologies for not following the NewGuy guidelines. Here is the link to my TV Signal Analysis Results ...
http://www.tvfool.com/?option=com_wr...4033077dfb8f79
... Experimenting with small changes to the length of one or both 'antenna-to-combiner' cables might make this work for you. A few folks are able to make this arrangement work ...
I have 12' cables between each antenna and the combiner. They could be shorter, about 6'. I could also move the two antennae closer together. I have each on a separate mast altho my original intention was to put them on the same one. Somehow i thought that keeping them separate would be better, but i have no real tech knowledge about this.
Should i put them on the same mast, or move them closer together, and should i make the cables as short as possible and still equal length? One is pointing almost directly East, the other almost directly West.
Compass i use [from my sailing days] ...
West, 263` compass ...
East, 87` compass ...
It took me a while to determine that i originally had the antenna pointing backwards. It is "obviously" a huge arrow, but it does not work that way. The tail is the pointer.
The antenna that i have may not be very good. They are DigiWav ANT-2110. DIGIWAV claims they are good for 70 miles. LAVA HD230 is an identical one, claims just 45 miles and a user rating of only 3.0 out of 5.0
Also the LAVA HD2805 claims 150 miles and a user rating of 4.9 out of 5.0 for about the same price.
Perhaps DIGIWAV is not being honest about their distance claim, and i may have better results with the LAVA2805.
DIGIWAV ANT2110 web page ...
http://www.digiwavetechnologies.com/...ge&PAGE_id=401
LAVA2805 web page ...
http://antennadeals.com/HD2805.html
LAVA HD230 web page ...
http://antennadeals.com/HD230.html
... Yes, a two antenna system often needs to be cabled with separate down-leads to an A/B switch or separate tuners.
Eventually it may cone down to this, but i am willing to experiment more if it might be fruitful.
Thanx again for the info and the assistance.
Mick
mdawdy is offline   Reply With Quote
