Old 16-Dec-2011, 6:42 AM   #4
2aa
Thank you so much for your help. Keep the CS2? I only minimally screwed it together -- I didn't even unpack their coax, as I used my own, so it would be easy to return (not much trace of use). I thought that it would be good as I saw a new one on a neighbor's roof, but now notice that it is no longer there -- they replaced it with a standard looking antenna. I also saw a CS4 at Amazon (didn't know they existed) -- would that be better than the CS2. Would it be better to get two HD7698P's? (One for each direction?) Since you didn't mention it, I'm assuming that an amplifier wouldn't be useful in the setup. If I had one HD7698P on my roof pointed to Phoenix, is it so directional that it wouldn't pick up the local channels, or would I really need two antennas (I don't mind, I'm just making sure)? Is there a device that combines the output of two antennas into a single line such that the TV sees all of the channels without a switch, or does the switch work the best?
Thank you again for all your help and insight!
2aa is offline   Reply With Quote
