Old 16-Dec-2011, 6:05 AM   #3
Tv Reception with Tv antennas
The Phoenix tv stations are Very Weak at your location. If you will like to ' reach out ' for them . then install a http://www.winegarddirect.com , HD7698P antenna on the roof and aim the HD7698P antenna at about 309 degree magnetic compass. Do Not connect the CS2 and the HD7698P antenna on to the same coax. The HD7698P antenna and coax will be a separate coax all the way to the location of the tv. The CS2 antenna and coax will be a separate coax all the way to the location of the tv. A , AB27RS remote control A/B antenna switch will be used to select the antenna that will be connected to the tv. Here are online places to buy , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com. For coax use RG-6 coax.
