Old 16-Dec-2011, 12:47 AM   #1
timotb
Antenna Position indicator
Do we always have to go outside, look at the antenna to see if is moving and which way its pointed, then try and point it in the rough direction of the desired station?
I bought one of those $30-35 directional, rotatable digital antenna kits on ebay. The antenna itself works great. The cheap system has a remote with two buttons and an amplifier with two lights. You can't tell which way its pointing from inside, or even if it is moving period. There is a green light on in the amplifier box that supposedly indicates antenna movement, but I find it's not always truthful when the motor is stuck.
I''m looking for a better antenna/rotor that can auto focus on strong signals, remember their locations and indicate the azimuth position in the house? Any thoughts? zip 44705
timotb is offline   Reply With Quote
