Old 15-Dec-2011, 11:28 PM   #9
Electron
Tv Reception with Tv antennas
I see no other receivable NBC television station or NBC digital subchannel. . My point of view is to evaluate the situation and arrive at a answer that will most likley produce desired results. Yes it is true that WMC-DT 5 NBC is a weak signal and digital tv signals are subject to interference in the VHF low band channels of 2 thru 6. However the way I see it is that it is Better to have tried and succeeded or have tried and not succeeded then to give up before even trying. And it is best to try with the best antenna for the job like a Winegard HD7084 or Winegard HD8200U or a Channel Master CM3671.
