Old 15-Dec-2011, 5:19 AM   #2
Electron
Tv Reception with Tv antennas
This recommendation is based on the tvfool Pending Applications Included , for analog and digital channels. The digital transition continues in Canada and the USA. Yes analog channels are still being transmitted in Canada and USA. The tv transmissions are showing Very Weak signals for digital and analog. Pending Applications Included is showing VHF channels in the ( 2 thru 13 ) range of channels as being receivable. With no current receivable UHF channels of 14 thru 69. However the digital transition is still in progress and some UHF tv stations/channels can very likley begin transmitting. My recommendation is a Very Large VHF/UHF antenna aimed at about 274 degree magnetic compass. A Channel Master CM3671 antenna. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. For a preamplifier use a CM7777. The reception can go down as low as analog channel CKND-TV 9 GTN. For more accurate transition information go to http://www.digitalhome.ca. Here is a place to buy antennas and etc. , in Canada , http://www.saveandreplay.com
