Tv Reception with Tv antennas
More , information , suggestions , and questions. The tv transmissions are VERY STRONG at your location , a amplified antenna in Any shape or form is not indicated. The amplifier in or on or connected to the antenna Will Overload and be 'a' cause of bad or no reception. The concrete buildings and the tv transmissions that are getting into your building are bouncing and reflecting tv transmissions all around , the tv digital tuner Does Not Like all the multipath (reflected signals). Here is my suggestion that is really a outright recommendation , Find A Way to get a coax cable from the south part of unit to the north part of the unit on the inside of the unit from room to room , go above ceiling panels , run the coax where the wall meets the ceiling or run the coax where the floor meets the wall , drill holes just above the base board , through the wall , run the coax through and in bath room cabinets that are mounted on the floor/wall , run the coax through/in kitchen cabinets. Get the coax from point A to point B in your living space. I will return with information of antennas to use and receiving reflected tv transmissions off of other buildings. O I forgot one , run the coax inside the airconditioning/heating duct work.
