Old 13-Dec-2011, 7:57 AM   #5
Originally Posted by JLEAF View Post
To be honest with you I'm not really sure if my TV is analog only or not. It is just a cheap old 10-15 year old CRT tv that I pulled out of my basement. I do have a DTV converter box and with that I'm able to get CHCH and CIII. To get CFTO I have to shut it off which was what made me think that CFTO was analog and the other two stations were digital. If my TV is the problem, I do have a fairly new plasma TV (maybe 2-3 years old) I could drag up there. Do you think that could solve my problem?
I'm quite certain the TV described would be limited to standard definition and equipped with only an analog tuner.
CKVR-DT, real channel 10 should be easy to receive with the antenna aimed SW if it's on the air.
When I enter the truncated LAT/LON coordinates from your TV Fool report, it indicates your location is about a mile offshore, in Lake Simcoe, roughly 3 miles NW of Big Bay Point. Do you live on a houseboat? I'm wondering how accurate your TV Fool report is... so I'm reluctant to suggest any changes to your antenna system at this point.
