Thanks for straightening that out for me.
I see . I'm less than 2 miles inside the vhf ring
I was using TV FOOL which is showing 24.100 kw's. I see the FCC is using the 33.7 kw number which is likely more accurate.
So this means the tv fool signal data for this channel is off by ~30% and the signals for whbf maybe actually higher than the OP 's channel 4 (not 3dB lower)?
That is actually encouraging cause it was looking pretty dismal (my quest for 4)
with you guys saying twice my signal level is unreliably with any antenna.
