Old 11-Dec-2011, 6:55 PM   #3
Tv Reception with Tv antennas
Install a http://www.channelmasterstore.com , CM5020 antenna aimed at about 18 degree magnetic compass. Here is how to aim antennas. http://www.kyes.com/antenna/pointing/pointing.html. Aim the front of the CM5020 at the top of the mountain for improved reception because some of the tv transmissions do bend a little down ward when passing over mountain and hill. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html . . For 1 tv connection , no amplifier will be used , a coax cable will go from the antenna to the one tv. For 2 tv's connected , install a CM3412 Distribution amplifier. For 3 or 4 tv's connected , install a CM3414 Distribution amplifier. . Here are places to buy , http://www.solidsignal.com , http://www.amazon.com , http://www.starkelectronic.com
