Old 10-Dec-2011, 10:13 PM   #1
slowhike
Cutting the cable
Well, I'll soon be cutting the cable.
I've been doing some research rather than just buy an antenna blindly. Only problem is, I'm not much into all the technical info I'm seeing... I get confused, sleepy even
So I'm just going to ask & hope you guys & gals aren't so tired of the basic newby questions that you boot me out Hopefully you will suggest what you think will likely take care of my needs.
In addition to local stations, it just seams that while I'm researching & buying an antenna, I may as well get set up to pick up as many stations as I can so I'll have more possibilities to choose from.
Though I get confused on all I've been trying to read, I get the impression that I may need two or even three antennas to get the full range of stations in my area.
Maybe I'll need an amplifier & a rotator too.
Here is my location info... http://www.tvfool.com/?option=com_wr...403359c6ee02ef
Thanks in advance. ...Tim
slowhike is offline   Reply With Quote
