Old 9-Dec-2011, 7:07 PM   #2
FTLOSM
Question Best Antenna choice based on my Detroit Suburbs information.
Hey everyone,
Ditching cable going with some OTA HD stuff hooked up thru my pc on the tv thru media center so i can use it like a DVR without the fees in addition to a roku with netflix and hulu, can't wait to cancel directv and the fees involved!
Here are my tvfool results based on my address I am in South Lyon Michigan btw.
http://www.tvfool.com/?option=com_wr...ec1294ca721552
Appears I have a mix if VHF HI and UHF channels (looking to pull in the eastern signals like nbc abc cbs approx 75-90 degrees east of me). Altho these are "Detroit" stations the towers are based out of the southfield area about 15-40 miles East of me.
I have no large buildings near me only mature forest preserve trees about 3-4 blocks away in that eastern direction.
I have tried an indoor amplified antenna in a few positions within the house with mixed results, I get about 4-5 channels about 75% signal most of the time but my hope is with a better antenna on the roof and pointed more exactly (vs rabbit ears), I will hopefully get a bit more and better strengths.
My questions come in as to what antennas should I consider and do i need a preamplifier as well, hopefully with the info given above selections might be a bit more clear, for now being winter (knowing it will look goofy) the antenna will be indoors in a high arched ceiling by a skylight, but once spring comes it will go on the roof via a mast like a satellite antenna approx 20-25 feet above ground.
Thanks for any input and advice on antenna choices and preamp info if needed.
Bill
FTLOSM is offline   Reply With Quote
