Old 9-Dec-2011, 6:07 PM   #11
You're faced with weak signals from Buffalo. Mounting the antenna higher may help, perhaps significantly. You can run a new TV Fool report using the new height if you would like to see the predicted difference.
If you post a TVFR based on a higher AGL, I'd be happy to comment on how that change would improve your opportunity to receive Buffalo signals.
(In post #2 of this thread, the CPA-19 is a preamp.)
