Old 13-May-2010, 10:46 AM   #11
kb2fzq
Originally Posted by salvasol View Post
You're right about the ebay antenna...that's why I'm taking my time before purchasing one, I'll if they guarantee that I'll get my money back if it doesn't work.
I already have a rotor (been lazy to install it). When you said: 75ohm coax, you mean new cable, Right??? I think I'm using RG59....Do you have any suggestion for the pre-amp and 75ohm coax???
I would get an assembled (connectors attached both ends) run of RG6 quad sheild...Home Improvement stores have 25, 50 and 100 foot runs.
I use the AntennaCraft 10G212 30db pre-amp, you can adjust it from 10 to 30db at the indoors power supply. Some say it has a high noise figure, but I've had nothing but good luck with it. Connect it all to the old RS antenna, rotor too, and you should be good.
kb2fzq is offline   Reply With Quote
