Old 8-Dec-2011, 10:23 PM   #18
JeffKnob
Jeff,
Adding the upgrade should have negligible (if any) effect on the C2's UHF reception. If your reception has been significantly affected, that suggests to me that either the diplexer is bad or one of the short coax cables is defective.
I will look up your order and will pull an upgrade kit from inventory, test it, and ship it out today as a replacement. Please let me know if this resolves your reception issues.
Steve
Thanks Steve. That is certainly worth a shot. I was definitely confused when this happened. I also plan on trying a new run of cable into my house because my overall performance doesn't seem to be as good as people are saying it should be. This was true even before I added the c2v upgrade. If after I replace the cable and the new c2v upgrade you are sending, I still don't get a good signal, I will definitely post again here. I am hopeful though that this will all work out.
Jeff
JeffKnob is offline   Reply With Quote
